Dean, if its No 7 its definately oil pressure.
Weren't Nos 1 or 2 on though? Should have been if oil pressure light was on.
Going from memory, here's a few I know;
No4; eng oil temp
No5; hyd oil temp
No6; hyd oil pressure
No7; eng oil pressure
No8; High beam
No9; Charge
No10; engine air filter
No11; hyd oil filter
Hope that helps Dean, been a few sleeps since i was on a mechanical horse!
Yep there all right. The Valtra has a flashing stop light come if things go horribly wrong such as running out of oils and fuels. which appears to be like number 1
If oil pressure was down the stop light should have come on. Any oil over the road?
I have rechecked everything, the engine oil is ok, I think it came on because the engine laboured and was almost stalling.
It doesn't do it now but the hyd pump doesn't sound a1, I'm suspecting the pump is siezing
