Thanks for the replies, so if everything works fine in 4wd when off road and in snow, it isn't the cv joints? it just making noises because it doesn't need to be in 4wd?
I could be a few things, but most likely it could be a cv joint on the front, those wheels are only ever turning and no power going through them then your loading them with torque in 4 wheel drive my shogun done the same.
It is most likely play in the cv's, however it can be a few other things as well, i hate to be the bearer of bad news but my previous fourtrak had exactly the same symptoms, it cost over 1k to rebuild the front hubs.
Ps, anyone saying it is normal..........WRONG. you will sometimes get a clunk as it engages, but not anything continuos unless there is a problem.
Driving on tarmac in 4wd will wind either the axle or transmission up eventually, they really dont like it.
If your selling it and it drives ok in 2wd without any noises, then use it as little as poss and get shot, you are most likely sitting on a heap of trouble that has the potential to let go at any time !
I have had 7 of these trucks, still got one now, they are one of the best trucks i have owned, rarely break but when they do make sure your wallet is ready !
Regards, Rob.
