It sounds like operator error TBH not the file.....its the way you are doing it!!
The file should be running parallel to the wear mark on the top of the tooth, and at 90 degrees to the bar. (some chains the file runs at 10 degrees up or don from the 90). TBH unless it is drastically different to the wear marks i wouldnt worry.
If the tooth is looking too elongated you are pointing down hill too far, and iff the tooth appears to short, ie the angle seems too flat from above, you are pointing up hill too much.
Thanks for that. Could well be me... :)
What you do is put the wee thing over the bar and then what I'm doing is sharpening it so that my file runs parallel with the edges of the thing that goes over the bar. Not sure if I should just be running the file in line with the wear mark.
I'm thinking I might get an oregon sure sharp. Anyone used one? I know it's good to sharpen by hand and that but would be good to have something to do it quick when out and about.
