Which timber have you found best for kindling and why
gensetsteve
Dry cherry is pretty good for kindling, well seasoned ash or hazel from coppicing / thinning work should be small enough to go through the machine or poplar like everyone else says!
Cherry bark along with Birch bark is like tar paper, even wet will go. If I'm clearing up old Cherry I collect the bark for fire starting, ok it's on a small scale.
I collect joist offcuts and split & smash them in half, the splitered ends will often start with a match.
  • Replies 22
Thanks for all the replies I am moving towards poplar. I think it is used for matches because it is easy to light but slow burning. Part of the reason for getting the ideal wood is not so much is it ideal as kindling, more is it efficent to pass through a kindlett without jamming up with nots or covering everything in sticky sap. I like Ash but expensive to buy in and a bit of a waste as kindling when it can make nice logs. Because I will be buying in volume I might as well buy the species most suitable.
