Cheers will ring on Monday,
The feed rollers on my 150 look slightly uneven and not completely paralell, is this down to anything bad? cant say i have noticed this on other machines ive used.
Nick.
Hi Nick
It may be that the bottom roller bearing has worn which is opposite end to the motor, it is a green plastic bearing which is easily replaced.
If you are calling on Monday, the spares section will be able to offer you a replacement.
regards
TW Tech Support
