Holly stem uses?
conkers
Does anyone know if large Holly stems are prized as I understood they are valued by woodturners and carvers.
Any other uses?
The ones I am refering to are about twenty foot long and up to ten to twenty inches diameter.
All my sections usually end up as firewood but I can't see these going the same way.
I know I sound clueless on the topic but how often do such large Holly stems crop up.
By the way: Consent was given for the fells- unreal!
and there will be replanting!
white woods are in with wood turners 4 2008 hollybrill but dont worry about using as firewood holly is one of only two woods you can burn brown or green
really? you can burn silver birch and ash green.
Where are you based, I am very interested in the holly butt
South lakes- Cumbria.
Unfortunatly the base of the tree seperated as it was four seperate stems.
There is a large pollard bowl though from about six foot up!
if it helps i can bring it down to manchester region , and if you are not desperate i can probably bring down yor way as i am all over the place:icon14:
Hi Chris. Am confused by your post, but am easily confused.:confused:
By The way did the Landy come rom Nene Overland?
I guess the reply was for me?, if it was that would be brilliant, just need to strike a deal with Conkers
