TW 190 rotor, rotor bearings and carrier shaft stub design pre and post 2008
Are there any fundamental changes in the design of the TW 190 rotor, rotor bearings, bearing cover plate and carrier shaft stub design on pre and post 2008 machines?
And if so what are they?
B101UK
In response to your question there have been no fundamental changes to the 190 rotor, the basics are still the same, however we are continually researching and have field trials underway in several areas, which until the tests are completed and approved are not open for discussion, is there a specific reason for your question ??
Tech Support
