hi m8 iv worked as a scaffy and i need to know what your plans are for it burd cage loading bay cat walk out rigers beam walk working lift how high what clips you are useing and how you are setting it up steel or ally pole
sorry so its for loading pm the the sizes and ill help you out no probs it go's on the span and saet up you need
gong by what you said then m8 you will need transom bracing
stop it twisting
and 2 fersard bracings frunt and back
all you are really do is knocking up a small ish working platform with out the boarded top lift
id knock that up in 2hours
list
6ft uprights x6
transoms x12 8.2ft
say x3 longens (21ft) satands to you and me cut to size for braces
8 swivel clips
12 bouble clips
24 single clips
6 pole feet
pole caps to stop you walking in to the end of the poles
think i may of helped you out there m8
pm me if you need more info
