Show us your defenders !!!!
christreeroot
  • Replies 111
Its a 300tdi, good old engine, very very reliable even with 160,000 on the clock. We have owned this vehicle for the past 7 years and when we got it only had 55,000 on the clock, it was also just a standard 110 hicap, the 6x6 conversion was done by Foley special vehicles
If you're going to run on 100% veg oil you need things like preheaters to keep the oil viscosity down. otherwise it will sooner or later block injectors and filters. It can melt the glue in filters so special high flow versions can be fitted, and natural rubber seals and hoses are best replaced with synthetic as if used oil is used especially, it attacks natural rubber and breaks down the lovely seals in the injection pump.
dont ask how I know :(
I considered changing to a 150 last year but decided that because the 130 had the turning circle of a double decker bus the 150 would be far worse. But there again the advantage would be you could have the same size tipper body plus have a tool cabinet behind the cab,
The turning circle is the same as a 130, pritty big but great for reversing close coupled chippers
