Hi
Please remove the 3 x cap head screws from the drive into the main roller, then it is a case of breaking the natural seal that has occurred between the drive and the roller, it may come out very easily or be a swine.
If you are replaceing the spline drive you can weld a bolt to the drive to aid removal of the old one, but be caref ul not to damage if you want to reuse.
Hope this helps
Regards
TW Tech Support.
