My entec 150 is lacking something as the chips are to coming out of the shute very fast or far, I have been adviced that it may be the fins on the fly wheel have worn. Would you be able to shed some light on it for me? And if you think it may be the fins would you have a link that i can order some new ones from thanks.
Josh
Hi Josh
Sorry for the delay in response.
The symptoms you describe could be worn fins, but also check that the area around the discharge tube entry is not clogged up and of course the discharge tube itself could be restricted.
Depending on the style and fins that you have replacements are readily available, the easiest way is to contact your nearest approved TW dealer who should advise you on part nos & costs, if that proves difficult contact TW spares dept who will assist.
If you call we will need the serial number of the unit to identify the type of fans fitted.
Hope this helps
Regards
Tech Support
Thank you I will get in touch with my local dealer and see what they can sort out. Thank you much appreciated
Hi Josh
Hope this helps
Regards
Tech Support
