I'm still working out all the controls on it Geoff, metal detectors have come a long way since the early days, ground balance, sensetivity, noise cancel, discrimination pattern and channel change ??
I've sussed out most of it, I just need some practice with it now :001_tongue:
Auto sensitivity is alright,but manual sensitivity will give more deapth,noise cancel do on wood/soil giving no signals in 'all metal',ie no metal under the coil when you do it,ground ballance make sure of the same.
Discrimination will stop yhe detector from signaling over that type of metal you wish to eliminate from your hearing,so the detector will go quiet or'null' when you sweep over it,you can create your own disc pattern rather than using the pre set ones (designed for usa type detecting),if you struggle mozza`has me number & its easier to explain on the old phone.:001_smile:
