Anyone using either an Alaskan Mill or Logosol Mill? Which one is the preferred mill for occasional planking/lumber conversion? Intend to use MS 660 with it. Cheers, Jim
Alaskan mills are by far the best than Logosol which I've heard fall apart after 2 weeks.... !
Ho ho - of course not really. I'd even go as far to say the build quality is better on the Logosol. But it depends what you are cutting. The Alaskan is a good quiick method for setting up and planking timber particularly different shape lumps.
Logosol was developed/built Sweden so the system is based around milling evenly shaped softwood logs. Of course you can cut other logs but it takes a longer set up time than the Alaskan and is more expensive when you compare it to what an Alaskan will do.
Have a look at videos on youtube and this will give you a better idea of what will work best for you.
