carving bars
treemeup
Hi, I've got a Husky 141 with carving bar & 1/4 sprocket. The bits came from D S Bennet (Dougie) in Tavistock, Devon. The bar is by Cannon, not sure what make the sprocket is:thumbup1:
I'm not certain that your saw is the same fitting but I expect some one will be along soon to clarify that one.
If you do get the bits you want for the saw keep an eye on the oil tank level if you're doing inticate stuff. When I use a standard bar on the 141 to do a few logs the fuel and oil last about the same.
Have you looked at ' a couple of jobs I finished today ' on the carving forum ?
The house sign took about 3/4 tank of fuel but almost 1 1/2 tanks of oil just because I dont carve at full revs. I need to watch the work-piece and chain for signs of oil starvation.The toytown Huskys have very simple oil pumps, but it's not a problem when you know about it:thumbup1:
