Wont stop!!?!?!?!? Ms200t
ScottyDSTreeCare
Usually its the earth wire in the switch or at other end, try and see if the contact is connecting with the switch ??
Yep, under the front end of the top handle is a little wire with a spade conection that may have come loose.
have same problem on 6mth old stihl hedgetrimmers, have to 'choke it to death', seems to have fixed itself and now the blower has started doing it..
Hedge trimmer is sometimes the earth again by the carb end of things same with blower, the connectors use to be quite brittel.
  • 3 weeks later...
