Hi, simple tree cutter here.
I found this on the bottom of a cherry tree trunk. The trees got a heavy lean. What affect does it have on the tree and the roots? Would you recommend taking out the tree?
fromt he size of the picture i can only suggest Ganoderma applanatum or Ganoderma australe, are you able to write messages with your fingernails on the underneath?
If its there, the tree is not in a good condition and should most likely come down. Although that can only be an assumption because there are no other pics
waiting for the hama hawk or super dave to correct me on the ID though!
