Hi all, I have been having problems with my Palax combi 600 wood processor, it was working fine until I moved it (using 3 point linkage), since then the ram doesnt work as it should, the manual handle doesnt work at all nor does the sensor that the log falls onto? I have had a 'tinker' with it but cant seem to suss it out, the ram does work as I can make it but the pressure doesnt seem to be what it was, I have checked all fluids, I think ive knocked something loose moving it but as I havnt a clue what im doing some advice would be great.
Many thanks in advance!!:thumbup1:
Away for 1wk so answer questions when I get back. :001_cool:
We have a palax forget the name but the ram handle presuming its the same sometimes sticks in the on position if you get under the machine and push the bottom of the handle out it usualy sorts it out I personally think its a bad design.
I no thats not the best explination but get under the machine and look at bottom of the handle and see if that is where the problem lies.
hi i also have a palax combi.it give me alot of trouble at first but i sorted it.check all wiring and sensors plus electronic box and plugs that push into the electronic box.i think the combi is a great unit easy fix.
