Hi John
It is better to use Hollow ground blades as they give a better life and chip, the flat ground blade has more material in contact with the tree and the efficiency suffers a little.
Angle of grind should be 40°
We offer a blade grinding service and guarantee that the blades you submit are the blades you receive back.
regards
TW Tech Support
