  • Replies 31
This is an important issue when using mechanical devices in treework IMO. Again, if you use an ascender or pair thereof to access the tree as I do, you want to be sure that this climbing aid can operate properly.If you must ascend thru' alot of ivy for example....use a rope and knot or in the very least back it up with a fail to safe system as leaves getting in the cams between the rope will cause the thing to slip....potentially dangerous.:sheep:
