its panels with concrete gravel boards. I did think of creeping into the garden late at night and fell it. Joking apart , thanks for the ideas.
put a concrete slotted post in either side of the tree, scribe the outline of the stem against the panel, cut it out. drop the panel into the slot then bolt through from the other side. use 50mm x 50mm pegs as wind brace along the bottom.
try and make the gap between t he posts as small as possible as it will be a weak point in the fence
