hi tw,
i have 2001 aborplant conversionTW150 tracked chipper, had some problems with rollers, intake would work and as soon as reverse was used the intake would no longer work, after 5 mins or so the intake would start again, we seemed to have resolved this replacing the hydraulic solonoid valve, intake and reverse working perfectly now . As the same time the no stress was not working, the cable had been knocked off, we have replaced the cable, now the rollers wont stop going on intake, no reverse or stop. At present i have by passed the no stress box, everything is working fine, feeding the bigger bits with stop button.
It is grey box no stress box. any obvious ideas?
cheers g
Hi Slasherscot
If you have inadvertingly pulled out the cables from the grey no stress box, I would strongly suspect that this has caused the integrated circuits to fail in the box due to being shorted out.
Depending on what grey box unit you have fitted it can be replaced with a new speed switch and sensor.
If you need help with part numbers etc please contact the Tech support line at Timberwolf but we will need to know the serial number of your machine to enable the settings to be programmed into the new part.
tel 01449 765800 option 2 or 3
regards
Timberwolf Tech Support.
