hi guys may need a new/ replacement grey box.
my entec 6 inch (2000/2001 model) has had on and off problems with its no stress over the last month and finally got some time to fix it for good.
if its not just a loose wire etc then ive been told i wont be able to source a new part (i havent tried yet),
has anyone got any idea of wether retro fitting a newer form from the newer 150's is a sensible posibility or does anyone have a no stress for my model knocking about?
thanks for any advice in advance:001_smile:
hi, i have a timberwolf 35/150 6" chipper (badged as entec on makers plate) that had the same problem. The grey anti stress box was playing up. You cant get this sort anymore so i am told but there is a retro fit newer version available that was supplied to me to fit, fitted it and now works a treat. Try giving mark a ring at M&H Arb Services 07766056148. He used to work for arborplant as engineer, who were Timberwolf dealers (entec) and set up for himself. Very good and wery helpful
There is a small resistor which went down on the circuit board when this happened to my mate's. It cost pence from RS components and it was soldered in place without a problem. Worth a try before you get a new box?
thanks for the replies
i dont realy have any electrickery knowledge - who'd do the fault finding? normal electrician?:blushing:
would probably be handy to repair the defunct box and keeping it as spair, even if i do end up replacing it in the short term.
well....... took it to local engineer and the box is working - due to slack belts:blushing:
i replaced a worn belt a little while ago and this promptly snapped taking off the fuel line and no doubt giving everything else in there a bit of a whipping
when i replaced it again i was a bit worried about over tightening- thinking that this was what caused the belt to break.
however i regret asking him to look over it - bottom and top roller splines on the way out, a shake on the rotor - not sure if its the bearings again or the shaft.
worn fans
potential £900 bill.
looking on the bright side at least the no stress is ok:001_tt2:
not sure whether to sell it on and replace it with something newer or to fix and keep it going in the knowledge that i know i wont get any surprises.:thumbdown:
