I’m just wondering if anyone has any experience of using reinforcing mesh to make firewood cages. The delivery on IBC totes is prohibitive but I have a few euro pallets that I could make a cage on. I was thinking of using the lightest reinforcing mesh for reinforcing concrete (A142 mesh)
Any advice from anyone who has tried this would be appreciated
I'm sure I've read on here some people are using stock fencing, if you're prepared to make a circle rather than square cornered rectangle then it doesn't need to be too strong. I've the same issue, only 10 ibcs but do have some more pallets.
Hi Dan thanks for your reply. The IBC cages seem a good idea but unless you can collect or buy more than I can take the delivery kills it
I stacked a cord in an open stack building a stacked wall around and putting all the irregular shaped stuff in the centre. To be honest throwing it into a cage would be much faster.
The reinforcing mesh seems to be the most cost effective way compared to other options. I was  thinking of making it into a circular shape and welding it so it can’t open out then fixing it onto a pallet base.
