If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
Magnolia
A magnolia tree on my land that had almost a second trunk (or a branch) fork away from the trunk very low to the ground had to be removed as it was obstructing the pathway.
Many years have past and now the tree has grown around the stump, but recently the middle of the stump began swelling. It swelled so much that pieces fell out, and in the hole it left a pool of water.
What’s in the hole is extremely rotted, and the water can’t escape.
I’m concerned this will kill the tree. The main part of the tree does look well however.
Im considering cutting a very shallow channel (width of a chain saw cut), to let the water out, and let it stay dry.
Either that or I just leave it?
thoughts?
1 answer to this question
Register a new accountSign in
