Some advice please. I've just picked up an old TW125 for small jobs. The original towhitch lock is missing.
Can anyone recommend a decent lock for locking onto tow ball while driving please?
I don't think there is anything decent, i think spud suggested one, think it was spud, but requires a new hitch but apparently if you loose the key you need to undo both the ball and hitch and replace both as you won't be able to part the two.
The little hole on the hitch, assuming it's this, tales this little barrels lock...
Maypole Trailer Coupling Lock for Bradley Autohead & Autojaw Hitches
SHARE.GOOGLE
Buy BRADLEY trailer hitches and hitch lock coupling locks at Towsure - the towbar and trailer specialists
he sort of thing to rely on but stops the opportunist.
Not t
Thanks, yeah maybe i could put one of those into the old lock slot and couple it with a chain.
  • 3 weeks later...
For locking while you're on the road, you should look for a coupler latch lock. It’s basically a small padlock with a long pin that goes through the handle on the hitch. This keeps the latch from popping open while you're driving and makes it harder for someone to unhitch the chipper if you stop at a shop. You can also get a locking hitch pin to make sure no one takes the whole ball mount off your vehicle.
