21 hours ago, cjdg said:
Thanks Steve, Its not a fuse as that would merely melt. What I saw was wreaths of smoke of something burning not melting.
Vet Mem The other half would not know one end of a multimeter from the other, let alone buy me one. She is more into socks and underpants! I have three and a reasonable amateur understanding of how to use them.  Can't see how that would help as when I eventually get to take it to bits I expect to find some charred electrical component   Was hoping that the excellent forum would have an idea of what was likely to be burned out by 12 v shoved in the wrong spur of the key switch  It has to be an electrical component or wire and affecting the starting process.  My guess would be some thing that is associated with the spark generation.
The multimeter was more to test the new start switch block compared to the old one before fitting rather than diagnosing the damage done by "slapping a new one on" and crossing ones fingers😉
Just look at what electrical kit resides around where the smoke was coming from...coils, starter, wiring and then check it out or swap it out. You could look at what the new switch energised that it shouldn't have, doesn't sound that nice...good luck.
Really helpful  Thanks guys. Makes sense. If weather is fine I will start to disassemble before going to Christmas lunch hosted for a change by offspring! Results to follow
  • 4 weeks later...
I have now identified the problem. It is the two resistors on the lead wires from the coil which have burned out. So I need
Either two second hand coil and wires and just swap them over
OR - subject to better knowledge on this forum - I cut the wires with the thermal insulation the coil side of the resistor  Find out what the value of the resistor is and rig up two new wires and reisistors connecting with clamps (possibly supplemented by solder first??) and try it out.
Thoughts?   Any one out there breaking a Countax and can sell the coils or if new at a sensible price?
Chris D52B75B5-CF8F-4F96-9C34-B545C31644A0_1_105_c.thumb.jpeg.88a83528fbd2830ae91bf917829e3b4c.jpeg
