23 hours ago, Stere said:
Better saw for less than both huskys would suit your needs i reckon
That was a bargain. I had two of the makita version / EA4300, liked them big time.
On 07/12/2025 at 12:01, Stubby said:
Sounds to me like you just need to pay someone else to do it ! 🙂
What ever gave you that idea. I worked a mechanic and welder most of my life, am wll used to cleaning up things.
I just hate bad designs.
Edited by Woodward
On 07/12/2025 at 19:22, scbk said:
From memory, the Husqy 435 and 440 are near enough the same saw, the 440 is just a bit higher tuned.
I had one, think it was the 435. It was fine, fairly plasticy as you would expect. Got replaced by battery saws which was a big improvement.
Yep, lots of plastic on them now. Not too many saws in the small sizes now that are not clam and plastic.
People say the clam shell design is not as robust as the split case type, but they are dam near
as expensive now as a split case saw in Ireland.
