Hello i have a Timberwolf PTO 150 chipper i have had this from new and it has had this problem the company came out twice to look at it but have never fixed it. Today it did it 4 times the forward rollers just stop and won't work i think it is a no stress problem i just move some wires and the relay box and it starts again anyone know whats the matter with it HELP:biggrin:
Its normally the spade connectors in the plug to the relay which open a little and become a loose connection.
Find the relays, unplug them and with a minature screwdriver push the spade connector prongs together a bit to make them a tighter fit
Thanks Dean i will try that when it stops tomorrow it does seem to be the relay box. How are you and the family?
Fine David, Just the usual catching up after xmas and owing the accountant, taxman and solictor all at the same time :001_rolleyes:
Hope you and yours are well :thumbup1:
