I've not used that one but I have a pair of shorty pruners that I climb with, mostly fruit tree prunes or anything small. Also great on holly. Telescopic would be safer for the fingers, I wouldnt want to be near anyone else using a telescopic!
What do you currently use?
While the one you linked looks good, 3m length would be limiting I think, compared to a 4.5m battery polesaw and same weight, much less versitile.
For telescopic these manually powered ones are really good. Very very light, often bring them up into the tree. Thicker stuff above 25mm is hard work if you have a lot of cuts to make.
Good price, they were £85. Come with a saw blade which I never used.
https://www.screwfix.com/p/magnusson-bypass-tree-loppers-157-1-2-4000mm-/852ty
Fiskars make almost the exact same thing, upx86, but it costs a good amount more without the blade.
Edited by kram
