Hi. Just bought an A60 Holder tractor. missing the front loader axle mounting brackets. I seem to have the short loader variant painted Holder green not the long loader I have seen usually grey.
Anyone running one of these?
I did see a picture on this site from about 10 years ago with the same loader as I have…. Is that guy still the right side of the daisies?
It would be great if someone could post some pictures specifically of the axle mounting brackets so I fabricate a set or does someone have a pair for sale?
Also going to need the hydraulic valve segments to sit under the steering column to operate the cylinders….. any contacts greatfully received
many thanks in advance
Do you know if it the same as the one fitted to the A55f?
The spool block can be non oem, the reason it is in a bank with the steering spool is because there is a priority flow to the steering IIRC
