*Stock clearance deal* .325 .043[1.1mm] Guarded Chains - Buy 1 get 2 Free
Need to clear out stock that we won't be re stocking - we now have unguarded .325 .043[1.1mm] chains and no longer want to have the guarded version (which Oregon and Husky do).
So buy 1 chain and get 2 free - while stocks last. ONLINE ONLY - if you can't get it to work whatsapp on 07752145001.
You need to have at least x3 chains in the basket.
Yes you can mix and match sizes.
No we are not doing this deal on any other chains right now.
Use code 325 in the basket - if you have x3 chains of this type in the basket it will remove 66% of the price (thus giving by 2 get 1 free).
WWW.CHAINSAWBARS.CO.UK
P-325-043-G-46 Panther Nano .325 .043[1.1mm] which tends to go on the newer smaller Husqvarna chainsaws as standard...
P-325-043-G-51 Panther .325 .043[1.1mm] which tends to go on the newer smaller Husqvarna chainsaws as standard type set...
P-325-043-G-59 Panther .325 .043[1.1mm] which tends to go on the newer smaller Husqvarna chainsaws as standard type set...
P-325-043-G-64 Panther .325 .043[1.1mm] which tends to go on the newer smaller Husqvarna chainsaws as standard type set...
Edited by Rob D
