Starting to work on my SRT climbing and looking into getting either a Notch Quickie CE or a ISC Ultra link small or large. Anyone have both? Pros cons? Appreciate any feedback.
Have the Ultralink small. Rarely ever use it as I since found I can use rings for cinching anchors. I'd like to use it more and tried last week on a stem removal. Fiddly to set up, would be easy to drop the pulley.
I use the small ultralink, use it for canopy anchors and really like it. Pulley does make it easier to retrieve.
Rings are a whole lot cheaper and totally bomb proof, probable the choice to go for starting out.
  • 2 months later...
Another alternative is a Maillon Rapide either a regular 10mm oval or 8mm pear shape. The pear shape Maillon Rapide are nice to install from the ground. I've been using these are over 10 years of SRT and never had a problem. Occasionally I'll use a pulley or quickie if going through multiple redirects to allow easy retrieval.
