Bulb is fine, I checked the old one when the same thing happened, it was fine but I bought a new one anyway. Now the same thing happened with the new one too. Apart from the bulb I replaced all the lines too (except the S shaped one from carb to purge bulb, since I couldn't find it anywhere, but it seems fine anyway).
Ok, some clarification needed, the s pipe as you call it, which connection on the purge bulb, long or short? when you depress the bulb does it push easily? does the bulb re inflate normally?
I think it's the short one, the one closer to the purge valve on carb, not sure right now. If you're thinking switched lines on purge bulb, thats not it because I've done it before and I couldn't even press the bulb easily.
It just worked for 6 months and then it suddenly stopped pulling fuel like before. Then it suddenly starts working again.
