Ford Ranger 57 plate single cab tipper - Heavy duty suspension upgrade
Rowan Elwell
Hi there - I’m looking to buy a 2007 Ford Ranger Tipper, and once converting the box I want to upgrade the suspension.
ive been recommended the heavy duty load and tow Pedders kit from a friend. This will come in at around £1700 including install.
Just wondering if people have recommendations for more budget but effective options? And also your opinions on fitting airbag suspension instead?
Thanks
Sounds very expensive.
Milners airbag kit is an afternoons work at the most by yourself- piece of cake on a tipper especially as you just lift the body out of the way. I run the air hose into the front footwell and have a 12v compressor there for adjusting it.
Do not forget to adjust your brake compensator, as the body will ride a lot higher! You should also get a drop down hitch otherwise the towball will be miles too high.
These engines respond well to a remap. I have two and they are fantastic trucks, super reliable.
Watch out for rust on a Ranger of that vintage too. It's not insurmountable- they usually go between the rear wheels and the back of the cab, so super easy access on a tipper. Just don't overpay. PM me a link to what you're looking at if you like.
Edited by doobin
