I have a MS 211/C from 2010 which had a running issue which was resolved with a new carb kit and a deep clean. I was looking for a replacement carb at one point,  but couldn't find one anywhere. Mine is a Zama S119b. There seem to be plenty of other Zamas available for MS 211s which look the same as mine from the outside. I'm guessing that the internals may be different and therefore would not work on my saw. Can anyone confirm this, or might a carb with a different number still work on my machine ?
This is the part number for the s119D 1139 120 0601
As long as the throttle linkage looks the same it should be OK. The differences are usually a change of throttle cable hence the fittings may be different or the H and L screws, limiters caps, type of tuning screwdriver required etc.
As above, rowencarbs are really good and will be able to help you out.
