  • 0
Leaning Magnolia - what to do
Question
Hello,
We recently moved into a new house with an established (little gem?) Magnolia in the back garden.
Our main issue is it is leaning pretty dramatically. Is there anything that would be recommended? Should I support the leaning branch to avoid breakage, should I cut back a bit etc? Does it need professional input? Is it fine as is?
Any advice would be much appreciated.
In case it helps at all
- The lean is in the direction of the prevailing wind, but I think it may have more to do with the a large overhanding ash tree in the neighbours garden. I've removed       the overhanging branches to allow more light hit the Magnolia.
- It has a dense crown but maybe too young for flowers, we certainly haven't seen any over the past six months.
- It had some shoots coming through the soil, which I think means it was planted too deep, so I've removed some soil in an attempt to get closer to the root flare.
- It had a piece of twine around the base of the trunk, which was cutting into it. I've removed this.
1 answer to this question
