Afternoon people. I have an entec 35 I believe. And the stress management isn’t working. The box its self is obviously the original. The green led is on so has power. It looks like it reads the teeth on the engine flywheel. It has a small dial in the box as well. Any ideas that could help me as it has just stalled and I would like to get it fixed.i can’t find any info online about these machines anywhere.
I had same problem when I had an entec, a friend of a friend was an electrical whizz and tried a couple of bits in the box but on re-fitting it still didn’t work. We changed it over to the Timberwolf 125/150 no stress system which is what the entec became 👍
hi . We can help you. There will be an upgrade for it. We will need a machine serial number and the details of the engine. The 35 should be the Kubota 35hp engine so if you can confirm that it will help. This helps us to know what the upper and lower rev settings it would have had originally.  You have the 108 tooth wheel I can see from your picture. Green Plant UK -  01483 235111 option 1 for parts.
