Honda hf1211 help?
sam8p
Hi wondering if anyone can help, got a honda hf1211 ride on at work it's been sat and was cranking the other day and today I've put fresh fuel in and no crank. I'm wondering A if mice have nibbled a wire I can't see or b of the ignition wiring is wrong as 1 wire wasn't attached when I took the fairing off. It has a double blue terminal, a brown/red terminal and a white and the ignition is stamped with L, B, S,G and M. I can't find a wiring diagram to check which should be where. Other than that is there any reason I'm not getting an ignition light? and the battery is charged.
Thanks
