Ms200t piston rings
KyleOZ
Hi all
Looking at piston rings for a ms200t and have noticed that on L&S Iit shows two part numbers for rings.
1114 034 3001
4119 034 3003
Both are showing as 40mmx1.5mm and visually look the same to me?
Guess maybe one will be the top ring?
Any one have experience of this?
Cheers
Part number 4119 034 3003 is the earlier, previous number for 1114 034 3001. 4119 034 3003 now supercedes to use part number 1114 034 3001. Both piston rings are the same part number- so you need to order Qty 2 1114 034 3001 and you will be fine.
Haven't checked what L&C are charging, but from Stihl the rrp including vat is £6.36 per ring.
Hope that helps.
