We're going to start setting up carving kits on the website to make it easier to buy carving kits so that you get a bar/sprocket/x2 chains
Stihl and Echo are the preferred carving saws mainly because Husky can be a nuisance to source 1/4 drive sprockets for and also you often need a gasket as they don't have a plate in the side cover
WWW.CHAINSAWBARS.CO.UK
CBW-30000 Cannon Bar Mount Pad - Stops Bar Oil Seepage. This pad by Cannon stops oil seepage on the chainsaws that...
Have set the first kit up here for the small Stihl more homeowner type saws - these can be good start up carving saws as they are easy to find and cheap to buy .
[U1-12] BN6A-0X30T-A-MS181-KIT Sugihara Tough Carver Dime Tip Kit 12″[30cm] 1/4 .050[1.3mm] 68 drive links [Stihl 017, 018, 021, 023, 025, MS170, MS171, MS180, MS181, MS190T, MS191T, MS211, MS230, MS231, MS241, MS250, MS251]
Carver Dime Tip Kit 12"[30cm] Stihl 017, 018, 021, 023, 025, MS170, MS171, MS180, MS181, MS190T, MS191T, MS211...
If you want a kit for your saw let us know on here on whatsapp 07508276769 and we shall set you up with one precious!
  • Haha 4
  • 1 month later...
Have started to add more Dime Kit carving kits to ebay where you get the sprocket/chain/bar
Ebay is pretty good when you need to list a lot of options that would otherwise clutter the website up with product listings:
WWW.EBAY.CO.UK
Find great deals on eBay for cannon+dime+kit. Shop with confidence.
