I recently bought a StihlHS75 and it will definitely need a new carb, coil, and fuel lines. But I noticed it is overly hard to pull...... is this normal for these trimmers? If not what could be the potential problem?
I have already had the pull rope assembly off and it works just fine
It could be dried fuel oil mix leaving too much oil residue in the bore. Try it with the plug removed and if it spins over fine, spray a bit of WD40 in the bore to wash the oil out.
Why does it need a new carb and coil? As others have said, if they are missing, it would be uneconomical to repair. Have you checked for a spark and cleaned and rebuilt the carb yet?
