If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
Peter12
Hello all, first post here.
We have what I thought was a small bush, at the front of our house. It turns out that they are 3 small trees intertwined, to appear as a bush. I've kept them pruned to an inverted pear shape, 2m 80cm high and around 1m 20cm at the widest point. The 3 trunks are 6cm, 12cm(Dogwood) and 15cm (Maple).
They are 1M away from the bay window at the front of our house, and we are on clay(Surrey). So the key concern here, is a potential for subsidence.
They surveyor did not pick up on the trees/bush when we purchased the property in early '15, it was about 1m 70cm high back then.
They are 2 Dogwood (Cornus sanguinea) and 1 Field maple (Acer campestre).
My question is, should I simply continue to prune, reduce in size or take out completely?
As mentioned, my primary concern is not to cause any damage to our property. Bearing in mind, the bay window foundations are more shallow than the rest of the property.
Opinions greatly appreciated, thank you.
2 answers to this question
Register a new accountSign in
