If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
ottocrat
Hi, last fall, I purchased an Emerald Sunshine Elm from a well known "Fast Growing" online store. The leader was cut, and although I was not happy with that, I did plant it. I had read this is not great, and asked the seller why this was done on a deciduous tree, and their tree expert sent this response to me:
"We complete Central Leader Pruning on most of our trees that would require it. This technique encourages the tree to grow branches and where the tree was pruned and a new branch will take over, to become the central leader. This helps lead to a properly shaped, matured tree. This will not stunt the growth of the tree, it will encourage better branching.
I hope this helps to explain this to you better. "
There is a small bud leafing out directly below the cut, a couple of the upper branches are also pruned like this. I'm not sure how to proceed. I read some about a new leader, but the upper branches are cut off at the ends as well.
Thanks
1 answer to this question
Register a new accountSign in
