does anywhere in the uk sharpen stump grinder teeth, green teeth and yellow jacket
Hats
You can get a diamond disc to do yourself or a setup for the green teeth. Depending where you get your greenteeth from they are cheap as chips so when done I'd throw them away(3-4.00 each) Used yellow jackets I can tickle up and put on a higher hp machine to still make brass . (7.50 each)
Being a tight arse myself I've been sharpening my multi tip teeth and got a good while out of them due to 14.00 a tooth plus vat. Good value for money though and done a lot of stumps.
Swapped them out today after a job with a lot of stone
Edited by swinny
Prices and plus vat
