Hi I have to fit 235015.power head to hydrostatic drive belt on a 2007 Hayter Condor. This belt seems too small by a good inch.
where is the adjustment to fit this belt.
Do I need to move engine?
Any advice appreciated.
Hi has the belt been fitted before to this power head as from memory the rotary power head was a different belt to the cylinder cutter head , they also did a 30”&36” rotary deck ,it’s a good few years since I hand these but I thought they had a slide pulley to tension the belt ,
If i remember right there should be an idler pulley (small steel wheel) that needs to be released so it slides back and forth giving you the room you need to fit the belt.
