Restocking numbers
  • 1 month later...
What it means is the FC expect 5 trees planted for every stem felled.  With 5 stems replanted the expectation will be one of the  five will get established and replace the felled stem.  Usually I would expect a minimum stocking density of 1100 stems per hectare.  If planting for productive purposes you can stipulate a higher restocking rate.  Ultimately the FC are regulating to make sure there is no net loss of canopy cover nationally.
