Ive got a Broseley evolution 26kw Boiler Stove, a 300 liter Joule Cyclone Thermal Store 2.0, Heat exchanger, Two UPS pumps, Controller and Pressure gauges etc. I bought the used system earlier this year and planned on installing it in the Dining Room as the main Central Heating for the House (16kw to water & 10kw to the room) with the 300 liter Thermal store kicking in in the morning to provide heat til the Stoves are lit but since we've had the original 1880 Sash & Case Windows replaced with new Modern equivalents I dont think we actually need it and will continue with the Kitchen & Living Room Stoves that seem to be doing a good job of heating the house and will use the oil boiler early in the mornings.
The Thermal Store can obviously store water for the Central Heating but can also supply domestic hot water at mains pressure.
JOULEUK.CO.UK
The Joule Cyclone Thermal Store 2.0 is the ideal solution for multi-energy applications. The hot water is produced through the freshwater module mounted
I paid £3000 and looking to get this back. Was a £13k install a few years ago and they only pulled it out when the RHI ended and they installed a Heat pump.
