Been a long time since I have had one of these apart but from memory, the crimped bit fits in to the white quadrant on the carb. I would think that you haven't got the cable sleeving set right at one end or the other. it has probably ridden out of its seat and is now catching making the cable inner too short.
Check the cable is set right at both ends and it should be fine.
