Hi, I am looking to install or have a stove installed in my living room.
My walls are all stud plasterboard insulation stapled to plywood and then the external brick.
I’m after a bit of expert advice on what the best option would be and what the regulations are for this wall setup or what work I need to do before installation.
I am looking at installing a Ekol apple pie with a surround so there is a low clearance  along with a twin wall flue. Just need to know if the plasterboard needs to be replaced with anything.
Any help is much appreciated and please ask any questions if I haven’t explained myself properly.
Rob
Best to get a certified installer to look at it than doing it yourself.
It's just not worth the risk of burning down the house, as even if you did it yourself you need building control to sign it off.
Edited by GarethM
