Right now I have disc bearings failed and it's bad case. Bearing removal was nightmare and new bearing is 480€ piece... Also engine is losing some oil some where... So just good Vermeer no need to worry
  • 1 year later...
On 29/04/2022 at 04:59, Squaredy said:
I think you need a skilled mechanic to take a look at it.  There are quite a few possible causes from a leaky fuel line to failed electronic ignition, or dirty carb muck in the fuel etc etc.  The guy who did the tune up perhaps doesn't have the in depth mechanical understanding to get to the bottom of it by the sound of it.
I'm not saying you won't get a clue from an internet forum, but there is no substitute for a skilled person spending an hour or two or four working on it.
